Model A1046 or A1095 / 1280x854 screen resolution
Upgrading RAM, what's compatible?
I thought I'd researched this enough, but I guess not. I'm trying to bring my old laptop up to speed. Currently had 2x 256Mb PC2700 DDR333MHz 200-pin SO-DIMM chips.
I'm trying to add 2Gb. Found a chip that's 1Gb PC3200 DDR400MHz 200-pin SO-DIMM.
I know there was one bit that was ok to go higher on without causing problems, thinking it was the PC3200 and not the 400MHz.
Can someone tell me which parts I have to match exactly and then which would be ok to stray from so that it would be compatible with this??
I know 2GB (2x1GB) is the Maximum RAM I can have, but is there a Max PC or MHz??
Please Help! And Thanks.
Score -1
3 Comments
We have to know EXACTLY which machine you have, some of the G4 PowerBooks used DDR and some DDR2. Please give the last three letters of your serial number. Thanks
by
DDR, it had DDR in it, and as far as I know, you can't put a DDR2 into a slot that originally had DDR.
by
Look in the battery compartment for your serial number please
by
Add a comment
1 Answer
Chosen Solution
All 15in PowerBook G4 Aluminum models use DDR except only the very last 15in model which was the 1.67GHz PowerPC 7447a uses DDR2. Your PowerBook takes PC2700 RAM modules and for best compatibility use only PC2700. The maximum is 2GB.
Just to make sure and be on the safe side go to the following link, find your model and read the specs page. Towards the bottom you will see the RAM specifications: http://www.everymac.com/systems/apple/po...
I hope this helps, good luck!!
Score 2
Add a comment
Add your answer
Brownbailey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 6,053
