Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
How to Remove iPhone passcode lock without updating iOS version
I have an iPhone 6 on iOS 9 that I forgot the passcode to. The phone is not stolen, it is clean IMEI and it has no iCloud lock. The phone is not logged into iCloud so I cannot wipe it like that. I've had this phone since it came out and I lost it a while back and I just recently found it. I just need some help if anyone knows how to get rid of the passcode lock without updating to the latest iOS version because I want to keep it on iOS 9. I don't mind losing everything on it, just if I can get access to the phone without updating to latest iOS version. Please, any help would be great.
The main goal is to restore and/or remove the passcode lock without updating.
Score 2
1 Comment
There are only ways to remove passcode from iPhone device. You can reset your passcode when synchronized with iTunes but this method will erase everything and settings on your device and should be used cautiously.
another ways is try iPhone screen locker program to remove passcode without losing data.
Source:
https://www.iseepassword.com/forgot-ipho...
by
Add a comment
Chosen Solution
I've not tried the following, but see if you can create a backup to Itunes (Create an account if you don't have one). Then follow these steps and let me know if you try and it works or what solution you have done to accomplish what you are trying to do.
https://support.apple.com/en-us/HT203434
Score 4
1 Comment:
I cannot create an itunes backup because when the phone is plugged into itunes, it tells me to enter the password for the phone so i can access it, but i do not remember the password. I appreciate the help though!
by
Add a comment
Most Helpful Answer
Here's how Apple says to do it:
https://support.apple.com/en-us/HT204306
Score 4
3 Comments:
This will restore and update the phone. I do not want to update the phone. But thanks for the reply!
by
You have to be able to read and follow the directions:
"When you see the option to Restore or Update, choose Restore."
by
it does not give me that option. it tells me to restore and update together. i appreciate the help though
by
Add a comment
The old iOS link is here:
http://www.iclarified.com/750/where-to-d...
On a PC you hold Shift and click restore to select the iOS file you downloaded from here.
On a Mac you hold Option.
However, you may not be able to accomplish this. iOS 9 signing servers have been shut down long ago. Unless you saved SHSH blobs using Tiny Umbrella https://tinyumbrella.org/, you may be out of luck.
Score 2
Add a comment
As far as I know, there are only two options to remove a forgotten iPhone passcode when you’ve locked out: Erase iPhone and Restore iPhone. If you don’t have an iCloud account used on the iPhone, you can’t remove forgotten iPhone passcode without doing a restore. In the process of restoring, your iOS must be updated to the latest version.
Score 1
Add a comment
it was so helpful because i unlock the pass
1 Comment:
How did you pass it can you please let me know thanks
by
Add a comment
As you can’t bypass passcode with iTunes and iCloud, maybe you can try a iOS passcode remover like Joyoshare iPasscode Unlocker. It can fix your problem and other issues like unlock Face ID, and Touch ID, and it’s quickly and safely.
Add a comment
Great Article, It was Very Helpful For Me. Here is a Detailed Post on Fix black facetime logo on iPhone
Add a comment
My experience tells me that iPhone passcode can be removed by iTunes, iCloud or 3rd-party tools such as FoneGeek iPhone Passcode Unlocker.
Add a comment
Add your answer
hussein hachem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 19,755
