Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
Front panel and Click wheel board replacement
I have a new front housing without the click wheel board. How do I remove the board from the front panel and then re-attatch to the new front housing. Is it glued and what type of glue for the re-install. Do I have to use a rework station heat blower to soften the old glue, and if so what temperature do you recommend?
Thanks
1 Comment:
[video|955]
Thanks Rachel for the quick reply.
This is a brand new faceplate! I need to figure out how to swap the touch board over. Check out the video if you like. Thanks again
by
Add a comment
1 Answer
According to the front panel replacement guide, it's supposed to have the wheel in the front panel. That's most clearly visible in Step 17 (the last step): iPod 3rd Generation Front Panel Replacement
The 2nd gen had a removable touch wheel, as seen in this video.
I'm not finding any evidence of people separating the touch wheel from the front panel. But if it's no good to you attached to the old front panel, it might be worth trying to separate. If you do succeed in this, please document it and add a section to the above 3rd Gen Front Panel guide, so as to help others in this position.
You may also want to add it to Stories: https://www.ifixit.com/Stories. There may well be a story about this in the 148 pages there, but I'm not seeing a keyword search function for that part of the website.
Best of luck!
Add a comment
Add your answer
Christopher South will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 113
