Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Questions View all
Question Closed
The mac is very slow!
My computer is very slow, I believe it is overheating. My hard drive broke and swapped it for another (128 gb SDD Run core). But the computer is getting slower with use and becomes unbearable slow! What can it be? problem may be the fan? how do you know?
Best regards
Alexander
2 Comments:
How full is your hard drive?
by
When did you swap the drive?
by
Add a comment
1 Answer
Hello there,
I've done some research on this topic and I have come by a "maybe the solution" solution (I'm loving the word play). If it is getting really hot, you might have to compensate a more powerful MacBook Air fan for a shorter battery life, but if you always use your laptop with your charger, then it's all cool.
There is an application which will allow you to control the "fan power" or the "threshold". This Mac utility will be able to help you control the fan level and hopefully keep your Mac cool as OS runs better on cooler system.
Anyways, here is the link for the application; http://www.lobotomo.com/products/FanCont...
Please note that I have not tried this application, but some of the reviews said that this application worked pretty well, so I guess it might a be a pretty good place to start with.
If this does not work, I will do additional research on this topic and hopefully come up with the solution.
"I hope I helped",
thanks!
Nonth
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,912
