Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
lost a small connector, phone still works
My phone stopped charging so I replaced the whole charging port, but this small connector right above the loud speaker fell off its wire. The thing is my phone works like normal. I can charge it, wifi works, 4g works, speaker works.
I dont understand, what does that connector do? I tried adding a photo
https://gyazo.com/db200d81f3e0a517ea5cac...
edit: The connector im talking about has a red circle around it on the picture, the wire it used to sit on has a green circle
2 Comments
Thanks, I tried called two people and had no problem with the signal, I guess its no a big problem then.
by
How possible network connector is open and phone still get network
by
Add a comment
Most Helpful Answer
This is the main cellular antenna, right now your phone is on secondary antenna so it still appears to work, but expect significant 4G speed reduction and increased battery drain.
Score 3
Add a comment
REF: iPhone 5s Lightning Connector Replacement
Look at Step 23. Are you referring to the antenna connector? Is it a round connector attached to a 1 inch long cable that pushes on top of its mating connector on the circuit board? I believe this is your primary/main antenna for cellular reception. Given that you have cellular reception, my guess the consequence for breaking this connector will be you won't have cellular reception is weaker signal areas where you used to have reception.
Score 1
Add a comment
Hey!
Shortly: This is the cell-antenna and you need to connect it on the board at this little round connector.
Score 1
Add a comment
Add your answer
soeharebrentpÄdvd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 65
