Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How to know what parts to replace after water damage.
Hi guys I just recently dropped my iPhone 5s in the ocean. I have never taken my iPhone apart but i feel confidant that I can. But after I do how will I know what parts to replace. I just need some guide so i know how to clean and test the parts.
Score 2
1 Comment
Would I need to replace my LCD too cause i have an iphone 6s
by
Add a comment
Chosen Solution
Alex the major issue you will run into is corrosion damage. Salt Water will get your components to corrode very severely. The very first thing you want to do is to not plug your phone in, try to sync it or turn it on. After that disassemble it by following this guide. You must remove all EMI shields. After that Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water (that might have helped right after it got submerged in the ocean;-). Use a soft brush and clean it very, very thouroughly with the sterile water. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Also, I suggest to replace the lightning connector. There are no standard item besides the battery and the lightning connector that need to be replaced. Cleaning will only get you to the point of proper troubleshooting. Unless your phone is properly cleaned, there is no way to do that. Keep in mind that water damage is the hardest to troubleshoot and to repair. Hope this helps, good luck.
Score 6
3 Comments:
Thanks you so much this has helped me. I have also read that i should soak my logic board in 90% alcohol, shoud I do this and how?
by
Yeah, you should. Just fill a Tupperware an inch or two. Put it in there, swish it around, on both sides
by
The guide I linked to in my answer will tell you how to do it.
by
Add a comment
Get a new battery and try this:
Electronics Water Damage
Score 5
5 Comments:
Ok but how do I know which parts to soak in alcohol?
by
Soak everything but the battery, camera and front panel.
by
Do not put that battery in IP. It will cause the battery to short
by
I said everything except the battery, front panel and camera tho
by
D'oh! Sorry. Yeah..I mean..I wouldn't start with dipping the camera. Ya know what..never mind. Do it. Been in the ocean
by
Add a comment
@gigabit87898
How to replace the battery in your iPhone 5s
iPhone 5s LCD and Digitizer Replacement
iPhone 5s Lightning Connector Replacement
iPhone 5s Battery
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s LCD and Digitizer Image
Product
$39.99
iPhone 5s Battery Image
Product
iPhone 5s Battery
$29.99
iPhone 5s Lightning Connector and Headphone Jack Image
Product
$24.99
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iPhone 5s Lightning Connector Image
Guide
Difficulty:
Moderate
1 - 2 hours
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Score 4
Add a comment
Hey! I new member in this site ! My iphone 5s droped in the pool… I open and take the logic board and clean with 90%+ isopropyl alcohol … After i put it in the phone and i try to turn on… The phone turn on! and shown the logo of iphone three times and then turn off.
I have recovered the process and turn on the phone and shown the logo one time and turn off. and now does nothing…
is there any explanation???
thnks !
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 16
All Time: 7,771
