Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s not charging when its switched on
When I connect my iPhone 5s to charger it says "accessories may not be supported ". I tried new cable , charger etc. even I cleanup iphone charging connector. It is charging only when it's switched off after plugin to charger. Also after charging it drains battery quickly. I am sure it is hardware fault can you guys help me to find this fault . Any body knows which capacitor, resistance, or ic I need to check for open or short. I have schematic of iphone5s so you can tell me part number also.
Kulbir_dh@yahoo.com
1 Comment
Actually few days back I use a bad car iphone charger when I connect it to my iPhone for 5-10 minutes iPhone got very hot at bottom area of rear side.( where charging port and headphone jack is). After that it is says "accessory may not supported ". Can I replace u2 Iv with soldering iron 60w.
Thanks for your replies
by
Add a comment
1 Answer
Chosen Solution
I'm not sure if you've tried replacing the Lightning dock or not, I would try that first. It could also be the battery. If both of these fail, it's likely the u2ic, if you have professional skills in microsoldering, I can post a link to guides and parts
How to replace the battery in your iPhone 5s
iPhone 5s Lightning Connector Replacement
iPhone 5s Battery
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Battery Image
Product
iPhone 5s Battery
$29.99
iPhone 5s Lightning Connector and Headphone Jack Image
Product
$24.99
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iPhone 5s Lightning Connector Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Add your answer
Kulbir will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 76
