Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
What CPU can I upgrade to?
I bought this computer for producing music. I find that 4 cores at 3.2ghz aren't nearly enough, because 1 VST maxes out an entire core (it cannot spread out a single instrument to more than one core, it only does this with multiple channel strips). I'm running on Sierra right now, and I was wondering if anyone could list some different high end processors that I would be able to upgrade too, or explain the rules for upgrading processors for me. It would be much appreciated! My imac: Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor
1 Comment
I think you're between a rock and a hard place on this one ;-{
While you could upgrade the system it will likely cost you more than selling yours so you can get a more powerful model (new or used). Don't forget the risks here of having to do all of the upgrading.
by
Add a comment
1 Answer
Most Helpful Answer
Go under the Apple to "about this Mac" and tell us which processor you have, What RAM configuration you have and what storage you have, please.
iMac Intel 27" EMC 2639 CPU Replacement
You have the slowest of the three available i5 processors. You can go to a higher speed i5 or go to an i7.
See this link to see about the Core i7 3.6 GHz CPU:
http://www.everymac.com/systems/apple/im...
Processor Speed: 3.4 GHz Processor Type: Core i5 (I5-4670)
Details: This model is powered by a 22 nm, 64-bit "Fourth Generation" Intel Mobile Core i5 "Haswell" (4670) processor with quad cores (four independent processor cores on a single silicon chip, each with one thread). Each core has a dedicated 256k level 2 cache and all processor cores share a single 6 MB level 3 cache. It also supports Turbo Boost 2.0 (up to 3.8 GHz) -- which "automatically boosts the processor speed based on workload" (so if an application is only using one of the four cores it will automatically increase the speed of the core in use and turn off the unused cores).
iMac Intel 27" EMC 2639 RAM Replacement
RAM Type: PC3-12800 DDR3 Min. RAM Speed: 1600 MHz
Details: Supports 1600 MHz PC3-12800 DDR3 SDRAM SO-DIMMs (204-pin).
Standard RAM: 8 GB Maximum RAM: 32 GB
iMac Intel 27" EMC 2639 Blade SSD Replacement
SSD Blade upgrade
https://eshop.macsales.com/item/OWC/SSDI...
iMac Intel 27" EMC 2639 Hard Drive Replacement
Details: *This model has a Serial ATA (6 Gb/s) connector for a 3.5" hard drive as well as a proprietary PCIe connector for an SSD. If the SSD is not installed at the time of purchase, the connector still is present and later professional or self-installation is possible.
At the time of purchase, Apple offered a 3 TB 7200 RPM hard drive for an extra US$150, a 1 TB or 3 TB "Fusion Drive" (which combines a 128 GB SSD and a 1 TB or 3 TB hard drive) for an extra US$200 or US$350, respectively, and a 256 GB, 512 GB, or 1 TB SSD for an extra US$200, US$500, or US$1000, respectively.
iMac Intel 27" EMC 2639 CPU Image
Guide
Difficulty:
Difficult
2 - 4 hours
iMac Intel 27" EMC 2639 Hard Drive Replacement Image
Guide
Difficulty:
Moderate
30 minutes - 2 hours
iMac Intel 27" EMC 2639 RAM Image
Guide
Difficulty:
Moderate
5 minutes
iMac Intel 27" EMC 2639 Blade SSD Image
Guide
Difficulty:
Difficult
1 - 3 hours
Score 4
7 Comments:
3.2 GHz Intel Core i5 is all it says
by
8 GB 1600 MHz DDR3 for the memory, and 1 TB
SATA Disk 10.9 for storage
by
See added links for CPU, RAM, Hard drive and SSD blade upgrades
by
You really need a i7 CPU here to gain Hyper-Threading. You also likely need to install a SSD (Apple's custom blade drive) if you don't already have it.
by
so if I wanted to put this in http://www.newegg.com/Product/Product.as... would it work, and what would I get from upgrading RAM along with it? I want to put a SSD in it, should I upgrade the HHD that's already in it too?
by
Show 2 more comments
Add a comment
Add your answer
Austen McKee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,727
