blue white power socket broken from mtherboard during hrd drive change
can this be repaired by me at home,with your help or does it require a solder at a computer shop or is my g4 destined for the bin?
Score -1
Add a comment
Chosen Solution
Don't throw away the 1.42 board !!
See my answer here:
Can I fix the power button Connector?
Score 3
1 Comment:
Your reference to yourself is better than mine. +
by
Add a comment
You can re-solder the socket back to the logic board. You can do the soldering yourself, or if you don't feel comfortable doing the soldering, then you can take it to a local repair shop and they may be able to do solder it for you.
Score 1
Add a comment
Add your answer
martin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 594
