The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683 Questions View all
What is a HFS volume Problem Mean?
I did an update for an doc.x file shut my computer off and now it will not boot up. I ran the disk utility program on it and it says their is an HFS volume error what does this mean?
Update
How many times should I try this. I have tried two times now and it still hasn't fixed the problem. I am starting to wonder if this has something to do with only having about 1.2 mb left of memory.
Currently I do not want to wipe my disk clean because, I do not have a back up done mostly all pictures. I took the computer into an apple store the tech was able to open my files but he wouldn't save anything unless I bought an eternal hard drive from him $300. I already have a 250mb external hard drive and I will try to load tiger onto it open up my files transfer them over and wipe hard drive clean by rebooting. Apple-Techs suggestion.
Any suggestions on how I can do this using my super drive on the disabled computer or should I do this by using a different mac.
Score -1
2 Comments
What is the exact error message?
by
Please post this as an Update to your Question. Only Answers belong here.
by
Add a comment
Chosen Solution
According to the info I find you need to boot into your system disk/ select utilities/ disk repair and run disk repair until it reports no trouble found.
http://support.apple.com/kb/ts1417
Score 4
Add a comment
$300 for an external hard drive is robbery. You can buy a 2 TB drive for $150 or a 500 GB for $60 here: http://www.bestbuy.com
Get the drive and do your backup then reformat your drive. If using 10.5 use Time Machine. 10.4 download SuperDuper and clone the drive: http://www.shirt-pocket.com/SuperDuper/S...
Score 2
1 Comment:
good answer +
by
Add a comment
Add your answer
Gideon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 762
