2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Frame slightly bent, CD's will not eject unless pressure is applied
The frame around the optical drive is slightly bent, not in a way you would normally notice. You have to look level across the keyboard to see a slight depression to the right of the trackpad above the CD drive (cd drive slot ever so slightly bent as well).
CD/DVDs will not eject unless pressure is applied to bend/straiten the frame slightly. With just with hand pressure around the optical drive area while someone else pushes the eject button.
Is it possible to bend, or manipulate the metal back to a suitable form to allow the CD drive to function again? (without making it worse, not fit back together or just have the metal go back into its current state once reassembled). If so, best way to do it?
Just looking for a way to make it functional again, when so close to working correctly on its own.
Score 1
1 Comment
the display frame is bent in the middle too, with a gap at both ends showing when the display is closed, .........another question i guess.......
by
Add a comment
Chosen Solution
Popsicle stick
to twist/press into shape. You may have to dismantle the upper case to press on the back.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 2
3 Comments:
fantastic idea, i will try tomorrow, I had thought of something similar to this, I just was not sure how the metal would respond and to what kind of tool. (i will definitely click on answered question once i give it a go and post any relavent info it if doesn't end up working and i try something else) Thank you.
by
good answer +
by
seems to work! I was only able to get to it today, and worked on it carefully for a while, i used a balsa type wood shim with a wider surface area and even thou there may be some additional manipulation needed to make it perfect and to ensure the problem won't return with continued use of the computer. The drive can now eject optical discs and it didn't take very long at all.Thank you.
by
Add a comment
super drive ejects "hard"
Score 2
1 Comment:
another good answer +
by
Add a comment
I took my MBP 15" A1226 to the Apple Store where I live to investigate the same problem. The genius bar guys took one of the black stick spudger thingys and wedged/twisted it back to shape. Looks normal now. However, I think the drive was already bad because it was already having problems recognizing burned CDs.
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,033
