Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
red and blue thin lines at the middle of the screen
my phone have red and blue thin lines at the middle, i dropped it earlier but i only noticed it after maybe 4 hours because it is very thin and only visible at dark colors like black, my phone is ok but the problem started when i noticed the lines, i can't type the letters on the middle, i can't touch everything on the middle and everything just freezes but when i pressed the lock button it become okay again but started acting up again after 1 hour or so then i pressed lock button and it become okay again until today but i'm scared that it will happen again so please help me.
update : when i touched the screen the lines will appear but when i'm not the lines will fade not totally disappearing, there's no problem but i just want to get rid of the lines
1 Comment
i forgot to say that when i touched the screen the lines will appear but when i'm not it will fade but not totally disappear
by
Add a comment
1 Answer
Chosen Solution
If the phone has not been repaired then the screen most likely has to be changed.
You can check the front panel connectors at the upper part of the logic board behind a metal plate to see if they are plugged in properly.
If reseating the connectors do not help then you will need to get the screen replaced.
Where you can buy a replacement screen:
iPhone 5 Screen
Guide for replacing the screen:
iPhone 5 Screen Replacement
iPhone 5 Screen Image
Product
iPhone 5 Screen
$34.99
Score 1
1 Comment:
i'm waiting for my phone to act again but fortunately it didn't. it is Okay for the whole day but if it does act again i will do your suggestion thank you
by
Add a comment
Add your answer
Jdeang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 9
All Time: 118
