Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Not charging, Charger light Green
Hi guys!!
Got a Macbook (mid 2007 model) that will not charge. It works off the power cord but cant charge the battery.
I charged the battery in another macbook and it works fine and holds charge. I also tried a different magsafe power adapter and same thing.
When plugged it, light turns GREEN and stays lit but in Max OSX says "Not Charging".
Tried a SMC reset no luck..
Any advice what it could be? Im looking at the DC-IN port but anyway i can narrow it down to that specifically?
Some say to clean the connector port, any recommendations with what? Qtip and nail remover?
Thanks!
Score -1
Add a comment
Chosen Solution
The most common on this is the magsafe board. Here's how to fix it: MacBook Core 2 Duo Magsafe Board Replacement
Here's the part: MacBook MagSafe DC-In Board
It could be the battery connector. This happens a lot if the book was set in liquid: MacBook Core 2 Duo Battery Connector Replacement
There are two versions so check before ordering. Here's the energy star one: MacBook Battery Connector/Sleep Sensor (Energy Star)
MacBook MagSafe DC-In Board Image
Product
$19.99
MacBook Battery Connector/Sleep Sensor (Energy Star) Image
Product
$17.99
MacBook Core 2 Duo Magsafe Board Image
Guide
Difficulty:
Moderate
30 minutes - 2 hours
MacBook Core 2 Duo Battery Connector Image
Guide
Difficulty:
Moderate
Score 1
Add a comment
So i just tried replacing both of those from my other macbook and i still get the "Not Charging" in the status bar.
Now im not quite sure what it could be or what it is.. It runs fine of the charger..
Add a comment
Im sad i did this one + Replacing MacBook Core 2 Duo Magsafe Board, try another charger and still the same symptoms :( wont charge and green light stay on. waste of time and money for my Macbook 2.4Ghz intel core 2 DUO White.
Any other solutions ?
Add a comment
Add your answer
Jeepo23 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 4,181
