What's going on with my Netgear WNDR3300 router?
Ok I have a fully updated Netgear Router WNDR3300.
My problem started last night when for no reason it stopped working.
So since I have a very good understanding of tech I tried to fix it with no results.
When I attempt to login to the router wirelessly via:192.168.1.2 I get text that says "IT WORKS!" and nothing else.
When I plug the router in via Ethernet and try to login I get the same page. The problem with ethernet is that the computer will not recognize the router is connected PC & Mac.
I tried to hard reset it by holding down the "reset button" for 10 seconds and also 30 seconds and 1 minute.
I also unplugged it and plugged it back in.
I am quite positive this is the result of malicious software so if anyone has any ideas on what to do I would appreciate it.
I have not been able to find any info on this on google or any forums I have been on.
-Varsity
2 Comments
Are you able to open a virtual terminal session on a pc over a console cable?
by rab777hp
I have had no response from the router via terminal at this time. It may be bricked. I'm going to try to hard flash it with dd-wrt firmware tonight. Thanks,
-Varsity
by varsityanchor
