The current line of iPod touch comprises seven (7) different generations.
2619 Questions View all
Why is my screen display white? Is something broken?
I'm not quite sure how long ago I bought it, but I'm pretty sure that this kind of damage isn't covered by warranty.
It's not the outer screen- that had a screen protector plus it's not damaged visibly, it's still whole. The actual display on the inside is probably damaged.
The iPod Touch itself responds to my finger at all points and still plays music fine even with external speaker, but all the color pretty much is in negative- the entire screen is pretty much white or light acid blue and it might be getting worse.
1.) What part is wrong with my iPod?
2.) Is it repairable- should I do it myself [with no experience] or take it to a shop {any suggestions for a repair place?}
Thanks for reading through that long description...and thank you for any help!
Score 1
2 Comments
Is is locked?
by
Well stated question +
by
Add a comment
Chosen Solution
try
a restore or a reset. Remember to backup first!
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
Score 2
1 Comment:
good start +
by
Add a comment
home/power 15sec.hold
Add a comment
Add your answer
Kate will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,171
