1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Mac mini A1176 1,83 , 2x512Gb no video, no sounds.
I have good 3 sticks ram.I insert any stick in 1 slot and mini Ok. If I insert second stick in 0 slot mini not working, if insert only one good stick in 0 slot mac no work- no sound only noise fan and cd ,no flash light . is it fatal ?how repair ?
Score -1
Add a comment
1 Answer
Chosen Solution
RAM ports do fail. Put the largest stick in the known working slot and just go on. I've seen a couple of reports of smaller RAM chips working in the failed port so I would try it with the smallest chip you have, there's a small chance the this might work. Be sure the slot is clear of debris and blow it out with canned air.
Score 2
2 Comments:
Thank you for your answers, but I would like to know because of what can go wrong in the slot to remove the cause.
I had already seen two such breakdowns with Apple products.
by
Add a comment
Add your answer
drova will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,537
