AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Why should my ac adapter get so hot?
I replaced my ac adapter about 6 months ago and it's getting very hot. Why?
Add a comment
Chosen Solution
It's shorting out. You need to replace it. Did you get an off brand? If you tell us which machine you have we can direct you to the correct replacement. Go to this link to help identify your Mac: http://www.ifixit.com/Mac-Parts
Score 2
1 Comment:
+ Please replace sooner rather than later--if it shorts completely it could cause a fire.
by
Add a comment
The more the laptop gets used, the warmer the adapter may become.A relatively warm power adapter is normal, especially when the laptopis being used and the battery is being charged
Add a comment
Add your answer
rsmsem2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,703
