Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Saved Imei in iPhone
Where it is saved in the iPHone IMEI?
Score 1
1 Comment
could you possibly rephrase the question?
by
Add a comment
Chosen Solution
Settings>general>about
5 Comments:
Sorry. I was thinking in hardware IMEI
by
Only on the outside of the phone. I don't believe it's printed anywhere on the logic board
by
Every phone has a unique IMEI: And I ask where is the IMEI is stored in which a chip. If I wanted to change the IMEI what CHIP must be replaced.
by
I can't advise you to do this. It would contribute to stealing
by
Dial *#06#
Changing the IMEI is possible but also illegal.
by
Add a comment
Most Helpful Answer
You can't, period.
Apple is a group of control freaks, they paired and encrypted almost every chip that has logic functions. So replacing just some of the chips will destroy the device.
For example in order to replace IMEI, the baseband and baseband flash ROM chip must be replaced together as a set, or the device dies. Also the device S/N must be rewritten to pair with the IMEI, or the phone will be denied activation. Rewriting S/N is not yet possible for iPhone 6s, so just forget about replacing chips.
If you replace the logic board, you'll run into another problem. The Touch ID sensor is paired with the CPU, Touch ID dies immediately when you replace just the board, and if you attempt to reinstall iOS, jackpot, the phone dies.
Score 2
Add a comment
Baseband chip is the one with the IMEI.
Add a comment
imei saved in iphone on eeprom ic
Add a comment
Add your answer
Wenzel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 666
