Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
I did a battery change and none of the buttons work
I changed my battery and my phone booted on when I plugged it in. Problem is that none of the sleep, volume or ringer work.. How can I Fix this??
Add a comment
Chosen Solution
you probably scraped the power/vol flex while removing the battery. The power/vol flex is a replaceable part, but a pain in the butt--order one and install. you can confirm that bad flex is actually the problem by first overlaying the new flex without installing it and plug it in. Then test before installing it.
Score 1
Add a comment
Most Helpful Answer
Check here and read down in the comment section, should help: How to replace your iPhone 5 battery
Score 1
Add a comment
Add your answer
cjbanville15 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 85
