Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Failed RAM MacBook Pro
Just bought 2 4gb RAM cards but they have failed to work. Place the old ones back in and they work fine.
I bought the ones recommend for my computer.
Anything i should do before installing them or are they likely just to be fully and need returned?
Thanks
P
Score 1
Add a comment
Most Helpful Answer
I agree with Matt. Make sure that you bought RAM with matching clock speeds (this will most often be measured in MHz).
Your specific machine should be running PC-8500 DDR3 @ 1066 MHz.
If you need to send those back.... Here is a trusted source. http://eshop.macsales.com/MyOWC/Upgrades...
There you can select your machine to specify which specific processor you're running as the spec in the question were vague.
However... if the RAM is DDR3 @ 1066 MHz...
Try running a PRAM Reset with the new RAM inserted. Hold down opt + command + P + R all at the same time at boot (before the screen appears)... Keep holding through the chime. Your screen will blacken and you should hear your drive initiate... then you can release all keys at the same time once you hear the second chime.
IF ...and only if that doesn't work: Run an SMC Reset. Now, I don't mean to scare you... but I do mean to caution you. Make sure that your drive is backed up on a drive other than the one installed in your machine. It doesn't happen often... but there are certain issues that trigger the SMC reset to wipe your drive.
However, once your drive is backed up and you have tried all the other steps to no avail ... and the RAM is compatible.... follow the directions found here: https://support.apple.com/en-us/HT201295
Good luck, and I wish you the best in getting your Mac back up and running with your new RAM.
This SHOULD work if the RAM is compatible.
Score 2
Add a comment
Check and make sure the clock speeds are compatible or equal to the ones previously installed. Common occurrence to accidentally buy some with a clock speed too fast for the machine to recognize properly. Best of luck!
Add a comment
Add your answer
paul will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 151
