Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Stuck in a loop after update attempt
Hi. I am working on an iphone 4S that refuses to restore and is stuck in a loop.
I have changed the battery and the charging port but to no avail. I have tried various 3rd party programs to try and reset it, but to no avail.
Phone is recognised by iTunes and the battery appears to be charging. Keep getting error 21 and 4005 during the restore process. The process crashes at this point.
There is nothing of importance on the phone and I just want to get it back to factory defaults. I took it to a repair shop and they were unsuccessful. They suggested that the fault may be caused by a faulty Baseband chip. (However they don't do chip changes) Does this sound plausible?
I don't have the expertise yet to change this chip, so if I have to send it to be changed I would like some second opinions as to whether the baseband chip idea sounds plausible or could it be something else?
Regards, Martin
Score 1
Add a comment
1 Answer
Chosen Solution
There is no easy answer here, you'd have to just use open-ended troubleshooting techniques at board level if the board will not restore in a known good housing.
This means measuring and comparing voltages and signals between this board and a known good board. Going down the rabbit hole on a 4s will consume days of time and is certainly not worth it. There are plenty of phones out there with solvable problems. My advice would be to consider this one a donor board and move on to the next phone
Score 2
1 Comment:
Thanks. Probably saved me a load of cash. I will return it to the customer. As they say, you can't fix em all.....Unfortunately.
by
Add a comment
Add your answer
martin nash will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 80
