LCD off but works in boot
I bought a 5s from an eBay seller a couple of weeks ago. Excellent condition w/box etc.
Last year, I replaced the battery in my old iPhone 4 with an extended life (gold) version with satisfying results.
I decided to do the same with the 5s.
Currently, if a power cord is plugged in, the boot screen appears briefly, as usual, then the screen is almost black but noticeably on. Specifically, the screen gives off a dark blue light but no icons or other shapes ever become visible, even dimly. The desktop never appears. Turning the silent switch does not activate the buzzer and I can't locate the phone with Find My iPhone using the iPhone 4, however, the phones are on separate accounts; but I checked the Apple iCloud website and the activation lock is on.
When I changed the battery, I popped the fingerprint and battery connectors but not any of the display connectors.
I just put in a new battery I got in the mail today.
Odd. The first thing I did was plug the charger in. I got the low charge screen, the one with the charger cable connector and battery icons. The existing charge was less than 7%, I think.
I thought, "Great, I'll leave the phone to charge for awhile then boot it."
Wrong.
When I picked up the phone, the same behavior was back.
I'm almost sure the lcd is not turning on. The dark-but-on screen follows the white-with-black-apple screen. If the charger is not in, the screen turns off; no glow whatsoever. If not, unlike the 4, the screen never turns completely off.
The phone is booting and waiting for keycode entry. When that doesn't happen after a few seconds, the phone shuts off as it usually does, unless, of course, the charger is in. I didn't see the low battery charge screen when I installed the extended (gold) battery because the battery was probably fully charged.
I would think the lcd is bad except for the low battery charge screen I saw when I first plugged in. If I had a way to safely drain the battery, I could check again, for the low battery screen.
If I had not seen the low battery screen, I would have thought the lcd is bad.
Any ideas?
One thing : I did not replace the two battery cover screws or the two pentalobe screws. Would that effect anything? I realize some company's designs use screws to electrically tie two circuits together.
Thank you,
Jim Julian
