Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Help me please! I've a weird message and the apple logo
Hello, I've a vert bad problem... My iPhone was normal (look here to see more ) but I don't know what the repairer have done! When I start the iPhone won't starts and the Apple Logo appears with a weird message in the top ! Please, help me, how to solve this problem ? I can't restore ! , Here is a picture :
*Sometimes(I think when I plugged the charger) it became RED SCREEN !!
Mise à jour (10/10/2015)
Hello, I've said that my iPhone when (it rests !) starts normally but when I'm in the lockscreen the digitizer don't work ! It can be the digitizer ??
Update (10/10/2015)
Hey, the repairer have said to me the digitizer is OUT OF SERVICE
Score 1
1 Comment
Possible? Yes. Replace it and see if that is what is causing this.
by
Add a comment
Chosen Solution
New ! The problem was the digitizer it's worked ! but I've another problem now the network is blocked in RESEARCHING ... and the iphone won't activate so I've tried to restore it with a error (47) !!
Add a comment
Most Helpful Answer
ilyesbouira, these messages are usually displayed because an individual component has gone bad. When the phone starts it runs a quick self check of all the systems, and when it encounters an error it displays error messages like this. It is common to see those on water damaged phones as well as phones with tore power flex, loose or broken compass, proximity sensor, cameras etc. you will have to take a close look at all the parts. start your phone up with a minimum of peripheries connected. I'd opt for just the display and the lightning port. Then re-evaluate by adding one component at a time.
Score 2
4 Comments:
Hello ! The iPhone has started like a charm this morning ! but the Touch Screen do not work and when the iPhone is confronted to a little choc (like put it in the table) it's powering off and I've Re-Started it with the weird message ! It can be the screen ?
by
Yes it can be. Anything that does not "answer" the self check during startup can cause this.
by
I've bring it to repairer. What is all the composants that can do this nand error ?
by
Any which one. Any flex, any camera, ambient light sensor, display etc.
by
Add a comment
I replaced a screen on a iPhone 5 and had the same error. I pulled the screen back off and removed and reset the display cables and it went away. I have checked with my customer at least 4 times since the repair and she has not had any problems. At the worst replace the screen assembly.
If a repair technician replaced the screen and it is acting like this why isn't he fixing it under warranty?
Score 1
Add a comment
When I have seen this error in the past, it has been a bad front camera/sensor flex.
Add a comment
This is almost certainly bad front camera flex from a replacement screen that came with all the small components pre-installed. That is very common. It is always better to have your installer transfer your original front cam/proximity sensor instead of using third party parts.
Add a comment
Add your answer
ilyesbouira will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 364
