Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Possible chip damage? Phone reboots every 2-4 minutes.
Hello,
A customer has brought me an iPhone 5C for power issues. Upon opening the iPhone I can see that the screen has been previously replaced. Phone appears to be clear of water damage.
The phone reboots every 2-4 minutes, either plugged in or not plugged into a charger. Replacing the battery makes no difference and restoring the phone through a DFU does not fix the issue.
I have managed to locate some board schematics but have not a clue which area and chips to look at.
Hope you can help.
Thank you kindly.
Score 1
2 Comments
same problem- you ever find a solution?
by
Unfortunately not yet. Definitely think this is chip related.
by
Add a comment
Most Helpful Answer
Bad battery or missing filter near battery connector
Score 3
2 Comments:
Thank you for your reply. I have tried a few batteries with the same result.
What am I looking for in terms of these filters?
Board examination is completely new to me.
Thank you!
by
I have same problem with iPhone 5c. I have three missing components. As in the picture at the top FL11 and the two below it. Jessa can you tell where I can find those replacement components. I have olso iPhone 4 donator board. In iPhone 4 chemantics there are FL11 but it still missing from every iPhone 4. There are many Fl components in iPhone 4. Is that same thing If I replace Fl11 with for example FL23?
by
Add a comment
The Filter you are looking for is FL11 and is extremely small. I've attached a picture with the filter circled in red.
Score 2
Add a comment
check for any components knocked off around the battery connector. unplug battery and charging port to inspect. microscope is recommended
Score 1
1 Comment:
Thank you. I will inspect under a microscope. Upon eye's view, the components seem to be okay when compared with another board.
by
Add a comment
Add your answer
zentech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 208
