How do I replace hard drive?
Remove old hard drive and put in new one.
It depends on which of the twelve generations of MacBook you have. The twelve generations cover nine years, and have four major incompatible technical architectures:
As you can see, each architecture has its own technique for installing/removing drives.
MacBook Core Duo Hard Drive Replacement
MacBook Core 2 Duo Hard Drive Replacement
MacBook Unibody Model A1278 Hard Drive Replacement
MacBook Unibody Model A1342 Hard Drive Replacement
The new Retina MacBook (released March 2015) does not currently have a drive replacement guide, but the teardown demonstrates that it doesn't use a traditional SATA hard drive. Instead, it uses a PCIe flash module inserted into an M.2 socket on the logic board. It may be a while before replacement drives in this format are available.
So, we first have to identify your computer before anything else can happen. The model number (A11181/A1278/A1342/A1534) will be silk-screened on the bottom case. If you can boot your computer, the more-specific Model Identifier is available from System Profiler, located in your /Applications/Utilities folder. The Model Identifier, which IDs the specific generation of the computer, is listed in Hardware Overview.
Guide
Difficulty:
Easy
5 - 30 minutes
Guide
Difficulty:
Easy
15 - 30 minutes
Guide
Difficulty:
Easy
15 - 30 minutes
Guide
Difficulty:
Moderate
10 - 30 minutes
Guide
Difficulty:
Moderate
Jnani, you did not give us enough information. Go to this site, pick your computer and then follow the guides.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,820
