Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
After battery replacement my screen flashes to the apple logo then off
I replaced my battery about 4 months ago and everything was fine until the past week. My phone started to turn off randomly and very often so i figured it was my battery being loose because i could hear it shake when i moved it. So i used double tape and taped my battery down where it isn't touching anything. After that my phone worked for a day and then it started to turn off again randomly and sometimes would just go to the apple logo then off and sometimes when I shook my phone it would work and when it was plugged in it would work. And finally starting today my phone wouldn't turn on when it was plugged in, so i took my phone apart and put everything back together and now when i tried to turn it on it flashes to the apple logo then goes to a dark grey. When I try to connect it to my apple computer it doesn't even recognize it.
Bottom line is, is it my battery that is bad or my hardware.
Thanks!
2 Comments
When you have the device open, does the battery appear to be seated securely?
by
yes and i unplugged it and replugged it many times
by
Add a comment
1 Answer
Most Helpful Answer
Lauren,
You're on the right track. Bad battery or bad board--or both! There is nothing about your case that points to one over the other. Grab another $10 battery and switch it in to see if that solves. Report back. We can help you more from there.
Score 1
4 Comments:
Today I received a new battery and I put it in and the same thing happens
by
As Jess said, this is most likely a board problem at this point. Can you post a picture of the connection terminal on the board?
by
What is the connection terminal?
by
The area on the board where the connector for the battery plugs in.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 175
