Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
I am still receiving "No Service"
Hello, I did an entire iPhone 5 teardown and rebuild. I have tried everything posted above, and I am still receiving "No Service" The iPhone recognizes when I remove the SIM card. I have tried different sim cards as well and resetting network settings. I do not know what is causing it to say No Service, but it is very annoying. EVERYTHING on this phone works besides cellular.
Since the charging port flex contains the cellular antenna I have recently looked around that area a lot. I will probably end up buying a new charging port assembly, but I want to make sure that is what is actually wrong. I have noticed the flex cable that wraps around the screw all the way in the bottom right hand corner of the phone it torn but still making contact (I am assuming that is what connects the signal to the frame?) and there is a flex cable that wraps over the top of the headphone jack that also got torn, but the headphone jack still works fine. So I am not sure what that cable connects too, and I do not see it in the part on eBay either. (http://www.ebay.com/itm/Black-Iphone-5-5...)
PLEASE help i have looked EVERYWHERE and cannot find anything to help!
Score 1
1 Comment
Ryan, post some images of the damaged ribbon cables with your question. That will allow us to see what you see. Use this guide Adding images to an existing question to help you with that
by
Add a comment
Most Helpful Answer
is this a phone that you just bought? Call the carrier with the IMEI to see if it has been blacklisted. Sometimes a good ESN can turn bad after a few days/weeks after someone turns it in for an insurance claim. That would make the phone show no service.
Score 1
Add a comment
Try going to >settings >time & date >click automatically set time and date off then back on again. Then restart the phone.
Add a comment
Connect to Wifi and turn flight mode on and off.
After this reboot your Phone and your phone will recognize your sim card
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 200
