Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone IC missing/ broken near sensor flex
Hi, the iPhone 5s I have fell and an IC broke and detached from the board.
Due to that it is showing lines on the display.
I want the name of IC as well as the solution for this IC as I don't have any scrap iPhone 5s board to take the IC from and change it. And I don't know the name of the IC.
The IC's position is near the sensor flex at the top right corner.
Here's the link to see image:
i1102.photobucket.com/albums/g444/irbaaz2/iphone5ICmissing_zpsb0sqpcab.png
http://i1102.photobucket.com/albums/g444...
Update
Yes It working in every aspect Network call and every different things.
See how the lines are comming :
[URL=http://s1102.photobucket.com/user/irbaaz...][IMG]http://i1102.photobucket.com/albums/g444...[/IMG][/URL]
when we move the lcd up or down after connecting it to socket the pattern of line of disturbance is changing and one time I got it full working wihtout any lines by doing this.
So should I assume that it has bad connector . ( It has digitizer connector also broken it worked one time when the LCD worked Fine ).
I have tried with new LCD also same result
Score 1
Add a comment
Chosen Solution
The absence of this component does not cause lines. Try to use the compass, you will find that it is not calibrating. So that's for the compass.
Lines are caused either by a bad screen cable, or screen cable not connected properly, or components on the board being damaged due to water damage or a bad drop (but not the ones you mentioned).
Score 2
1 Comment:
irbaaz,like Rany says, that part is U16 which is the AK8963C compass. Here is the datasheet. No, that part will not cause any lines on your display.
by
Add a comment
Yes, that is the compass ic. In the iPhone 5, it is left off all the time since it is often hit for water damage. I know on the 5s it is a two layer ic. Replacing it would really be tough.
Out of interest---can you confirm that this phone still gets cell service and recognizes a SIM? I have a colleague troubleshooting a 5s with no compass ic right now. We assume it would be unrelated to SIM detection from the schematic, but it would be nice to confirm.
Line on your display: show us a picture for more guidance.
Thin lines = likely bad LCD. solve with new screen.
A white line always in the same place = bad digitizer connector--send out for new connector
Zebra stripe lines across the display (plus/minus no touch) = drop damage to touch ic or related circuitry.
good luck!
jessa
Score 1
Add a comment
Add your answer
irbaaz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 2,755
