Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Resistor values near battery connector
Does anyone know the value of the resistor (capacitor? I've seen it labeled as both but neither post had values) circled in the picture. Caught it with a fingernail and now the battery charging indicator won't update. I'm reasonably good at smd soldering - just need to order the right part!
Score 4
1 Comment
I have same problem with my old iPadmini, but I can not find a inductor 240ohm 0.2A, would you please advise the inductor can be replace by a SMD resistor 240ohm too?
by
Add a comment
Chosen Solution
Aaron Teter, that is reference designator FL7500. It is a 240Ohm 0.2A filter (fixed inductor) in a 0201 package. Something like this will work.
Score 5
2 Comments:
Just wondering how you figure this information out. Your answers are always useful. Thanks for your help.
by
Can you please tell me if i can take this filter out from diffrent device.I have iphoen 5s,6 and ipad 3 monther board.If yes can you please guide me.
by
Add a comment
You have a lot of exposed ground plane here. Cover that with a conformal coating before replacing your filter. Don't allow any solder to adhere to that ground and short your gas gauge line
Score 2
1 Comment:
Someone make jumper? Give some idea please.
by
Add a comment
Add your answer
Aaron Teter will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 9
All Time: 2,269
