Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
Question Closed
Black plastic display coming away from metal casing
I went through this tutorial to see if I could fix my problem on my late 2008 Mac book pro. The black part of the display is coming away from the silver body of the lid. I can't seem to work out how it is attached and how to fix it, any suggestions would be much appreciated.
Add a comment
1 Answer
Chosen Solution
See this step - though I've not done this one they are "friction" or "snap" fits.
Note: The small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
So if one of the "tangs" are broken a dab of glue may be your only solution. As you can see it would be a huge mount of work (and risk) to try to replace the strip (if you could find a replacement strip)
If this answer is acceptable please remember to return and mark it accepted.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 123
