Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Front camera not working/ Damage to logic board
During a screen replacement, I have damaged two resistors on the logic board FL15 and C194. As a result, front camera does not work. When I switch the camera from rear to front, the screen stays blurry and the app freezes. After looking closer at schematics, FL15 seems to be related to front cam and C194 seems to related to proximity sensor (which is strange because proximity sensor seems to be working okay). So my questions is, what would you advice about fixing these two resistors? Do they need to be replaced (how?) or just somehow connected by soldering? I do not want to do the job myself as these components are extremely small. The marked photo is my board and the unmarked photo is how it is supposed to look like. thanks in advance.
Score 1
2 Comments
Thank you guys to both of you. Jessa, I will be sending this to you tomorrow.
by
Gator, first off neither one of those parts is a "resistor". You identified their reference designators right. C194 is a 1.0UF 6.3V 20% capacitor in a 0201-1 package, FL15 is a 70ohm 300mA filter choke (fixed inductor). I am sure that the Apple engineers know their stuff and would not use components unless they are needed. I suggest that you replace the parts.
by
Add a comment
1 Answer
Most Helpful Answer
Ha--I just talked to you!
To add--in iPhones, filters like FL15 are required for continuity in the line. They allow DC voltage to pass through them while filtering AC noise. The loss of a filter is the loss of a circuit.
In iPhones, capacitors like C194, serve a more indirect function. A capacitor isn't a component that is required for continuity in the line. The job of the capacitor is to assist the circuit in maintaining a clear, even signal. For example, if a component was putting out signal spikes that passed through a capacitor, then the capacitor could absorb these signal spikes and turn them into an even signal line. If the capacitor is not there, then the signal will still exist in the line, it just may be a little more 'rough' than it would be otherwise.
Not sure if that makes sense--- but that is my current pea-brained understanding of basic electronics. I'm pretty good at component level repair, but just getting my feet wet learning to really understand the schematics.
Hopefully somebody else (cough *OldTurkey* cough) can give us even more guidance.
Jessa
Score 4
4 Comments:
Just to be clear--if you connect across C194 you will short out your phone
by
That is absolutely correct
by
Is there a part on the Iphone 5 logicboard similar to the C194. I only have iphone 5 motherboard for parts and i need to replace C194. Any help would be greatly appriciated. my front camera is gone.
Thank you.
by
never mind, found one on the Iphone 4S near the front camera fpc.
Cheers.
by
Add a comment
Add your answer
Gator will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 10,891
