Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
3092 Questions View all
Hard disc failed after few weeks of working with YOSEMITE
My hard disc with 1tb failed with bad sectors which could not be repaired at my end and had to send it necessarily to service provider who sits at 500kms away and all my work came to a grinding halt,my question is whether with an external hard disc can I load and continue working with the external hard disc,are there any symptoms where in we can understand that the hard disc is going to fail and take preventive measures,I am from INDIA and I cannot switch over to products other than APPLE please guide me
Thank you NARAYANAN LAKSHMANAN INDIA
Score 1
Add a comment
Chosen Solution
Be sure to replace the hard drive/IR cable whenever you have a hard drive issue on this model of machine.
Score 1
Add a comment
The short answer to your immediate question is: Yes, you can boot from an external drive (USB, FireWire or Thunderbolt), as long as the external drive has an operating system that will boot your computer. If you have a bootable flash drive or DVD around and a Time Machine backup, you can:
  1. attach your external HD and Time Machine drive
  2. boot from your flash/DVD
  3. restore your last Time Machine backup to the external drive
Once you've done that, you should be able to reboot from the external drive. Your data will be in the same state as the last time you did a backup.
Add a comment
Add your answer
NARAYANAN LAKSHMANAN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 87
