Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Bluetooth Not Available after Module Upgrade
I upgraded Bluetooth module in a 2010 MacBook Pro, after doing so, I get a no Bluetooth device available message. My wifi, which I believe is part of the upgraded module, works perfectly. With that new module not working, I then reinstalled the old Bluetooth card and the message still appeared and Bluetooth was unavailable. I tried the resets outlined in many posts including SMC and PRAM. I am using yosemite. To help clarify, both cards are showing in system profile when they are installed in the network section. Bluetooth is where it says is missing. Any ideas?
Score -1
Add a comment
1 Answer
Did you first enable Bluetooh in System Preferences> and then add a Bluethooth Service to your network? At the bottom of the left hand pane there are a + a - and a * (gear). Click the + and create a Bluetooth connection.
One other thing to try - from System Preferences make a new account and see if you can enable Bluetooth in it.
If this answer is acceptable please remember to return and mark it accepted.
Add a comment
Add your answer
danielkite will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 224
