Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone reboots after apple logo
I have some very strange problems with my iPhone 4S (16GB), I got it from my friend and he doesn't know why the iPhone can't start anymore.
If I turn on the phone, I see the Apple Logo and after some seconds, the phones crashes and is restarting in a loop, always crashing on the Apple Logo. It looks like something is termenating the phone - is there a problem with the bootloader?
I tried several things:
  • Turn phone in DFU-Mode -> iTunes Recovery -> iPhone is restarting during the Recovery and loops
  • Turn phone in Recovery-Mode -> iTunes Recovery -> iPhone is restarting during the Recovery and loops again
  • Turn phone on and hold the upper volume button -> reboots after some more seconds
I tried to restore the IPSW file from Apple Server for iOS 7.1.2.
Here is a video:
https://vimeo.com/107279805
I also can't restore any files with programs like "Wondershare Dr. Fone" - the program needs a phone which can boot up.
So, does anyone know any more tricks or something how I can "repair" the iPhone?
OR: Does it look like a "dead battery"?
Thanks!
1 Comment
Start with battery replacement.
by
Add a comment
Most Helpful Answer
Disconnect but don't reconnect.. Use charger to turn phone on
Score 1
1 Comment:
Amazing! Thank you con - I could turn on the phone with disconnected power flex cable. I then re-plugged it and Button works again - with unplugged battery.
So I tried something else: Power flex cable plugged in again (all cables are plugged in) except the batterie!
I can turn on the phone with the charger and battery disconnected. With connected battery, phone crashes...
Whats wrong here - problem with the charging IC, is it possible to repair?
Thank you very much!
by
Add a comment
I would change the battery as battery problem can cause this problem.
2 Comments:
I tried today to change the battery (Repair Kit from ifixit).
Badly the same issue... The phone crashes when I turn it on or when I trie to recover in Recovery or DFU-Mode...
Does anyone know how I can fix this, is this a "normal" problem?
by
Would a new logic board fix the problem? Where can I get one?
by
Add a comment
Hello try disconnecting power button flex from motherboard then try booting
This worked on a iPhone 4 I did once
1 Comment:
Hi, you mean to disconnect the power button flex cable and then plug it in again? Then reassembling and start the phone?
by
Add a comment
i think the issue is in charging IC need to replace it.
Add a comment
My iPhone 4s is having the same issue but when I disconnect battery and connect with just power flex connected to charger it doesn't even boot while I know that iPhone 4&4s can boot with just power cable connected and better removed. I think it's an NAND \ memory issue. Here is my link for iphone 4s problem https://www.youtube.com/watch?v=66aTUgxP...
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,340
