Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Front camera blurred. Freezes. Resistor value. SOLVED!
Hi.
Since i had to disconnect and reconnect the front screen several times, i unfortunately broke one of the resistors of the logic board.
Does anyone have the schematics for an iPhone 5, so i can get the correct resistor value. Thank you.
Okay. I solved this one. Just solder the two points... simply short circuit. Is works.
Score 1
3 Comments
by
Can u shows the picture of the soldered place?
by
See the red circle on the attached picture in post #1. Beware that the footprint is very small. You will need some kepton tape or a steady hand to do this :)
by
Add a comment
Chosen Solution
No--it's FL14 a data filter. If it were a capacitor he'd have shorted out his phone by bridging it!
Knocking off FL14 will break the continuity in the camera line, so although replacing it with another one is ideal, bridging the filter pads like you've done will restore continuity in the line.
Score 1
3 Comments:
Correct, it's a filter. I didn't have the component, and it is not easy to solder since it is a 01005 housing. So I short circuit it. Works fine.
by
Hi jessabethany.
I believe i have this problem too.
In my case the one that was accidently knocked off is FL15.
Is it safe if i could just put the jumper in there?
by
my motherboard is like that picture but the schematic diagram in not tha same its only one coil and one capacitor i can't understand what's wrong why they are not the same ?!
by
Add a comment
Most Helpful Answer
This is the information from the schematic, C192 56PF 5% 2 6.3V NP0-C0G 01005
Score 1
1 Comment:
My own at the moment is the back light. The screen is dark but phone work. What if i bridge or just circuit? I need to restore backlight.
by
Add a comment
Add your answer
Klaus M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 5,710
