battery connector ok, battery ok Works only on charger
Hello , i am searching for troubleshooting for this problem but no answer yet.
I have an iphone 4s which works only on charger. When i put a battery after many hours it boots for 4-5 sec and then it shows the low battery icon.
i ve checked the battery (tried and second one). Works fine.
the battery connector is ok . i am testing with a multimeter and there isnt a broken connection.
Is there a possibility that this could be an ic or cap or something similar on the board ? a power ic for example.
Thank you in advance.
2 Comments
Give us more details of your testing that you believe ruled out faulty battery and faulty battery connector on board.
Are you saying that with a battery that is fully charged by another device will not allow this device to boot?---you are sure this isn't just a charging system problem (which is often board-related).
What troubleshooting of the battery connector have you done?
by jessabethany
i take the mainboard and put it on an iphone 4s that works perfect and the problem is still there. when i disconnect the cable it scwitches of . So i guess its mainboard issue.
by Marios
