Computer shuts down randomly on battery power
I have a Macbook (Mid-2009, non-unibody, NVIDIA 9400M) that is randomly shutting down. When the computer is plugged into the power adapter, it will work perfectly fine and not exhibit any problems. However, if I unplug the computer and work solely on battery power, the computer will randomly shut down without any warning. In order to turn the computer back on, I will need to press the power button. The battery is new and has 2 cycles on it - I have swapped another known good battery from another Macbook and the problem still exists.
A search on the console log shows that the computer has previous shutdown causes 3 or 0.
Also, I opened up the computer to visually inspect the logic board and saw that there is nothing plugged into the J5520 (TEMP) socket - could this be the source of the problem? I'll attach a picture:
Thanks in advance for any help.
One more thing - I booted the computer from memtest86 while on battery power and the computer still exhibited the same issue - it would shutdown randomly, without any warning. I think it's safe to rule out any improper OS installation.
by Jack Byrnes
This happens to my 2006 15" MacBook Pro as well. I run Windows as the default operating system and always attributed it to improper power management by the OS. Are you by any chance using a non-native OS also?
by Chris Green
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - MacBook5,2 - A1181 - 2330
by mayer
@Chris - I've tried running 10.6 Snow Leopard and 10.9 Mavericks but the computer still shuts down randomly.
@Mayer - Yes, that is the correct computer in question.
by Jack Byrnes
@machead3 - i've unchecked the 'put hard disks to sleep when possible' feature. one thing to add though - i have an SSD in this computer, with trim enabler installed.
by Jack Byrnes
Show 6 more comments
