Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
Question Closed
SSD instead of ATA SuperDrive
Hi, I decide to install a primary SSD instead of my SuperDrive in my old 24 inch , 2,4 C2D . But it's a ATA interface for the SuperDrive . Is it slow down SSD or be
Okay? My plan to install system on the SSD and all files
On to the HDD- SATA.
Please let me know if someone did it before
Thank you
2 Comments
I just install SSD instead of Superdrive and keep my HDD in place.
Installed system on the SSD . Performed system performance test, SSD read and wright is not more than 50MB per sec. Looks like that slow than HDD.
HDD performed at 70MB per sec. Any Ideas how to improve a speed?
Thanks
by
You'll need to swap the drives around putting the SSD where the HD is now located to gain the sped benefit of the SATA port. Then put the HD in the Optical drive carrier which has a slower PATA port. While it would be nice to have two higher speed SATA ports you're stuck here with one slower PATA port.
by
Add a comment
1 Answer
Chosen Solution
You'll want to swap your drives around putting the SSD where your HD is now and put the HD in the PATA to SATA carrier in place of your optical drive for the best setup.
You will need to extend the HD thermo sensor wire to reach over and put the optical drive thermo sensor onto the SSD. That way the sensors make sense when you are reviewing them in monitoring software.
Here's the IFIXIT guide for the dual HD kit. Installing iMac Intel 24" EMC 2134 and 2211 Dual Hard Drive
Score 3
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,325
