iBook charger plug replacement
Can I replace just the plug end on my charger, the part that plugs into the computer? iBook 12" 1.33ghz
You can try to buy a broken charger off ebay and splice on that end onto your charger, if you know how to solder wires you should be fine.
If the tip is broken off, it's probably lodged in the DC IN port and you will need to remove it (the tip) or replace the DC IN port. Here's how to replace to port: iBook G4 12" 1.33 GHz DC-In Board Replacement
Here's the part: http://www.ifixit.com/Mac-Parts/iBook-G4...
This isn't what the poster is asking.
I'd assume if it was broken somehow it has been crushed, that happens a lot to the iBook/PowerBook chargers.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,618
