Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Very slow 802.11n airport conection and lack of range
I replaced the airport card in my A1811 MacBook with a MacBook Pro several years ago and have not had the range or especially speed tha t was expected - virtually no improvement over the orginal card. The card is supposedly Apple # MA688Z/B. Is there firmware/ software or an antenna wiring problem. Is this the same card that you are selling for the update the Core Duo?
Score -1
1 Comment
I have susequently reversed the antenna wires at the (802.11n) airport card within the MacBook and now have satisfactory speed at 60+ feet.
by
Add a comment
Chosen Solution
Did you update the base station also? You won't see n speeds without an n base station. Ralph
Score 1
Add a comment
Most Helpful Answer
maybe its not your computer but the wifi base stations you connect to?
or something upstream?
your antenna could be part od the problem too.
this is a brad question - can only elicit a general answer
Score 1
Add a comment
I have updated the base station - airport extreme to the latest software / firmware. I feel it is related to the antenna as the closer I get to the base station the faster it gets. When I am over 30 feet it is very slow. My new MacBook works very well this distance. Could I have hooked the antenna wires up backwards or do I need different antennas?
1 Comment:
your ld antenna may not be working well with the frequencies used in 'n'
IIRC we have 2 bands of frequency used in WiFi - so your suspicion could be correct
by
Add a comment
Add your answer
minicoopers will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,904
