Model A1106 / 1280x854 screen resolution
90 Questions View all
I have a CD-Rom stuck in my DVD/CD drive.
I press the eject button and the CD remains in the dirve
Score 1
1 Comment
did you look ito the manual to see the ways of ejecting the CD - I would think you did ...
by
Add a comment
Chosen Solution
turn off the computer then turn it back on and as the computer is coming back on hold left click down
ps- press the power button then immediatly hold down the click button, don't wait for anything
Score 2
Add a comment
if above did not work here's another thing to try: boot the machine into Open Firmware by doing the following:
1. restart the machine, and immediately hold down these 4 keys simultaneously: Cmd-Option-O-F (that's a letter O, not a numeral zero before the F)
the machine should boot but show a white screen instead of the normal Mac OS
2. at the prompt, type: eject cd then press Return
this should hopefully eject the disc and show OK on the screen.
3. at the prompt, type: mac-boot then press Return
your machine should boot normally
Score 1
Add a comment
Check this hint:
http://www.macosxhints.com/article.php?s...
Add a comment
Actually, one more thing, this has worked whenever I've had stuck disks, verify the hard disk, and run the drutil -eject shell command at the same time.
Add a comment
Add your answer
dski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,183
