2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
MacBookPro Keyboard & touchpad wont work after disconnecting
After cleaning the fans and reassembling, computer starts fine but keyboard and touchpad wont work. Everything else seems to work fine. I followed step by step instructions on manual. Connected upper case cable twice, still won't work. Might be connecting something wrong?
Any tips or advise?
Thanks!
Score -1
2 Comments
There doesn't seem to be any damage done to the ribbon cable or connector, i will try replacing the cable to see if this works. Ill keep you posted. Thanks.
by
I have examined the ribbon cable and connector thoroughly and there doesn't seem to be any cuts. The strange thing is that sometimes they work fine and all of a sudden they stop working for several days. Any other ideas?
by
Add a comment
Chosen Solution
Quite possibly you loosened or damaged the ribbon cable or connector, reexamine them for cuts/nicks and a poor connection. (You might need to use a magnifying glass)
Remember to return and mark accepted the answer that best solves your problem.
Score 2
1 Comment:
by
Add a comment
Most Helpful Answer
Try replacing the cable. If that doesn't work, replace the upper case. If that doesn't work, replace the logic board.
Score 2
2 Comments:
Since that cable is built into the keyboard, how do you do this? Why replace the uppercase rather than just the keyboard? Nothing indicates that it needs a logic board replacement.
by
I was referring to the cable that connects the upper case to the logic board. And, yes, thank you for correcting me. I did mean the keyboard.
by
Add a comment
Add your answer
Hector will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 606
