Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Question Closed
MacBook Pro Charge slowly
I have a Macbook pro 15'' 2010. 4 moths ago, I replaced the logic board to 2012 version because of some beyond repair damages. I also replaced the battery in order to adapt the logic board and update RAM and SSD.
The Macbook Pro works fine. It has almost 4 hours usage time(I7 CPU). The only problem is that it needs 14-16 hours for fully charging. I am an university students. Some classes requires using computers, so I do not have too much time for charging.
I have Windows and Mac systems in my Macbook pro, so it will not be software problems. Also, when the Macbook pro is off, I plug the charger, the charger almost is cold. Therefore, it still needs long time when the computer is off.
I have been genius bar. They tested my Macbook pro and the charger. They even used an new charger to test and replaced an new battery for me. Unfortunately, the problem still exists.
I think there is not enough power go through the battery. I cannot fix the problem, and I need a help.
1 Comment
Please give us the Axxx number on your AC charger. Thanks
by
Add a comment
1 Answer
Chosen Solution
Use a multimeter to test the output of your MagSafe adapter. The pin outs are list on the right side of this Wiki: http://en.wikipedia.org/wiki/MagSafe
Score 1
2 Comments:
I think the MagSafe adapter is OK because I used other 3 adapters to charge my Macbook Pro. It gets the result.
by
Well if you know what's OK. I can't help you.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,705
