2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Hard drive height limitations
Hello,
I want to upgrade my hard drive in my MacBook white unibody (late 2009).
Are 12.5mm laptop hard drives compatible with my MacBook? Or it has to be 9.5mm?
Thanks!
Score 1
Add a comment
Most Helpful Answer
9.5mm, the unibody is a thin computer, so the hard drive has to be thin, you can check under the battery cover. It has to be 2.5" wide as well
Score 2
Add a comment
Okay, thanks. 1 more question. How do I know that the hard drive is 9.5mm and not 12.5mm?
1 Comment:
Before you buy it, look at the spec's or ask the vendor.
If you have it in front of you, measure it - 12.5mm=1/2", 10mm=1/10"less ....
by
Add a comment
Most listings will specify whether a drive is 9.5mm or 12.5mm. For example, the listing here at ifixit for a 640 GB 5400 RPM WD SATA hard drive specifies 2.5 inches and 9.5mm under "Dimensions": [linked product missing or disabled: IF107-086]
Add a comment
Add your answer
okatidubi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,712
