Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
366 Questions View all
USB semi-fried? And no love of airtravel!
OK.
It appears my one single solitary USB port is poopx0red and will only work partially. I suppose I should count my blessings, but what that means is that it will not properly eject discs (tried drive on alternate Airs, no problems), I cannot use a powered hub for squat, causes problems with some USB devices, and, oddly (and perhaps this is not related), the thing just DIES above 2000ft or so when flying (a pressure thing, I bet; perhaps not related). Anyway TL;DR - Can I replace the USB port myself? I have no fear of basic soldering and my warranty is definitely out (first model). Is this recommended? More importantly: Are there cheap replacement parts and will I kill my MB by attempting this (assuming I'm not an idiot)?
Thanks!
Comments:
I'm sorry for the delay in response, as I've been away, but let me assure you I was able to read your responses that same day and I just wanted to say: You Guys Rock.
Thanks so much for your help. I've placed the order for the part and look forward to performing the repair. I never imagined you could make it so easy for me; I was expecting to have to jump through flaming hoops to even approach the answer... let alone order the part and have a GUIDE
I'm... super grateful to you all.
Thanks,
~a
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
I'm not sure this is the answer to your problem--it could be the logic board but this URL will take you through replacing the usb port. Ralph
MacBook Air Models A1237 and A1304 Port Hatch Assembly Replacement
Score 2
Comments:
iFixit has the part in stock. Ralph
MacBook Air (Original) Port Hatch Assembly
by
Might be a good idea for him to check in system profiler if the USB port is showing up when it doesn't work.
by
Wouldn't hurt. I assumed that since it worked intermittently that it was showing up. Ralph
by
Nice research and links +
by
Add a comment
Add your answer
anatinus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 796
