The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Can I change hard drives from one playstation to another
I have a playstation 3 that will not read the disks, so I have purchased another ps3 just like the one I have. Can i take the hard drive out of the first one and put it in the second one so I don't lose all my game data
Score 6
2 Comments
Shane’s assessment is correct. You cannot just slip in the old hdd, and get all your saves back.
by
I need to take hard drive out of old psp3 but it has no flapt. cannot find answer on the web. square looking box belonged to my son not like one in your photo, that I got was easy.
by
Add a comment
Most Helpful Answer
Upgrade to the newest firmware on both PS3s and there will be a new utility in the settings that will allow you to copy all of your files from one PS3 to the other using an ethernet cable (you can even transfer copy protected files and game saves that don't normally allow copying).
You cannot just remove a hard drive from one PS3 and put it in another and expect all information to transfer over. You will have to format the drive.
Score 9
3 Comments:
Since the systems are hardware identicle, there should be no problem swaping a hard drive from one PS3 to another, if it were to be used in a PC, or other device it would need to be formatted, but it should be able to be swaped without a problem, just like Xbox 360 Drives.
by
Great assessment!
by
what if only one hard drive is working , i have two ps3’s , the one i use is very slow, but has all my stuff in it , and the other one works just fine exept its hard drive is corrupted and it wont even turn on
by
Add a comment
Yes, depending on whether you have a slim, or not, the procedure is different, but you should have no problem with compatibility. I don't have a PS3, so I'm not sure how you remove the slim's hard drive, but I have worked on "Fat" PS3's and the hard drive is on the side, just pop off the cover, and remove one screw, then the drive.
Score 3
1 Comment:
PS3 door in the front to remove the hard drive 1 screw remove the cover and you pull it out
by
Add a comment
As Shane said, it's physically possible to take the drive out of one PS3 and into another but it won't preserve all your data. Use the transfer utility, it works quite well and if you've only got a few things then it won't take too long.
Another way, depending on what you want to save, is to backup your saved games etc to a USB hard drive and then copy them to the new PS3. You can't copy everything, but by-and-large you can copy everything you can't replace by downloading again.
Score 2
1 Comment:
What if only one of the ps3 is functioning the other was baught for parts and wont even turn on im trying to bypass having to unjailbreak a ps3 that i purchased i dont want the jailbreak which way is easier
by
Add a comment
If you have the new firmware update 3,56 it isnt possibel to swap / upgrade harddrive in a ps3.. I hope Sony soon will com with a new update to fix this bug - so my PS3 can come up and running again.
Score 2
1 Comment:
I am not aware of the bug in the 3.56 firmware update.
by
Add a comment
buy ps plus and save your data on your account then get new ps3 then you will be able to still have yoru stuff
Score 2
Add a comment
You could back up your data though the backup utility in the PS3 system's menu. Get a USb flash drive, or if needed a USB external USB drive to back up your system settings, game data and game saves.
As for any downloadable content, any games or media purchase from the Play Station Store can be re downloaded with out an additional charge.
Score 1
Add a comment
Another point is puchased/downladed games or DLC may need to be declassified/deactivated in Settings to allow re-download use on another PS3. Multiple downloaded copies of same purchased game wont work across several PS3's. Most important is use Backup Utility or PS Plus backup before any HDD transfer.
Add a comment
I have a ps3 working just fine, but its NOT backwards compatible. I want to get another ps3, that has no hdd, and IS backward compatible and put my drive in that one. Will this work? Its a new 2 TB drive i ghosted while back and has worked ok ever since.
1 Comment:
im pretty sure all you can use is a 1gb 7200 rpm drive. it maxes out @ 1tb
by
Add a comment
Add your answer
Teena will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 43
Past 30 Days: 160
All Time: 103,660
