1 TB 7200 RPM 3.5" Hard Drive
$99.95
Product code: IF107-083
Product Overview
Important: To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Serial ATA interface. Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models). This drive has a form factor of 3.5".
Compatibility
  • 1.8, 1.9, or 2.0 GHz 17" iMac G5s (EMC No. 2055)
  • All 20" iMac G5s
  • All Intel iMacs (excluding 2011 and up 21.5" and 27" models)
  • All G5 Power Macs
Product Details
  • Interface: SATA 6.0 Gb/s
  • Speed: 7200 RPM
  • Dimensions: 3.5" (88.9mm) wide x 1" (25.4mm) tall
  • Capacity: 1 TB Unformatted
  • Cache: 32MB
$99.95 Toshiba
Condition:
New
Warranty:
3-year manufacturer warranty
Notes:
Model #: DT01ACA100
$99.95 Western Digital
Condition:
New
Warranty:
Notes:
Model #: WD10EZEX
$99.95 Seagate
Condition:
New
Warranty:
Notes:
Model #: ST1000DM003
Add to Cart »
Replacement Guides
iMac G5 17" Model A1058
Difficulty: Moderate
iMac G5 17" Model A1144
iMac G5 20" Model A1076
iMac G5 20" Model A1145
iMac Intel 17"
iMac Intel 20" EMC 2105 and 2118
iMac Intel 20" EMC 2133 and 2210
iMac Intel 20" EMC 2266
iMac Intel 21.5" EMC 2308
iMac Intel 21.5" EMC 2389
iMac Intel 24" EMC 2111
iMac Intel 27" EMC 2309 and 2374
iMac Intel 27" EMC 2390
Compatibility
1.8 GHz (EMC No. 2055)
2 GHz
1.9 GHz
1.8 GHz
2 GHz
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
2 GHz (EMC No. 2105)
2.16 GHz
2.33 GHz
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2266)
3.06 GHz (Core 2 Duo)
3.33 GHz (Core 2 Duo)
3.06 GHz (Core i3)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz (EMC No. 2267)
iMac Intel 27"
2.66 GHz (Quad Core i5)
2.8 GHz (Quad Core i5)
2.8 GHz (Quad Core i7)
2.93 GHz (Quad Core i7)
3.2 GHz (Core i3)
3.6 GHz (Core i5)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Stories
My Problem
The original 320GB drive was dying. The computer still serves me well so it was worth replacing the drive.
My Fix
The repair went very smoothly. With the instructions provided it was not hard at all. Now I have a 1TB drive to boot! (pun intended)
My Advice
While you have the iMac open you should clean out the years of dust built up inside. A can of air and a brush work well.
My Problem
The computer worked fine, but the hard drive was seven years old, about the time they stop working. So my friend and I replaced the hard drive and increased the memory.
My Fix
With your replacement parts, and your how to articles, it was very easy. My friend had already replaced the hard drives in his and his daughters iMacs, so he had no trouble guiding me through the procedure. We are both retired, and are thinking of doing this to make a little extra money, at least in the winter time.
My Advice
Make sure you have the right tools, have a good place to work on your repair, and most of all, DON'T BE AFRAID. The info on this site will get you through with no problems.
My Problem
My only concern was the $40 overnight charge and I did not get the product until the middle of the second day.
My Fix
Great
My Advice
Still learning
My Problem
My original hard drive failed and I wanted to increase my ram power
My Fix
Repairs went smoothly but I wasn't able to install MAC OS X in to the hard drive.
My Advice
It would be nice to give the exact steps to install MAC OS X using your hard drive.
My Problem
My original hd is broken and I replaced it with a new one
My Fix
Following your precious instructions has been very much easier
My Advice
If you need help for any replacement of parts, trust ifixit
My Problem
The drive in my iMac failed.
My Fix
After ordering the parts from iFixit and using the guide on-line, the repair went very smooth and easy (it took a little more than an hour from start to finish). The only difference is that I removed the drive thermal sensor before removing the drive (the removal of the sensor was easier with the drive secured in the chassis then unplugging the sensor). Otherwise I followed the steps in order and everything was as documented.
My Advice
I don't know how I was able to take anything apart without the magnetic project mat (it held the screws in place and I was able to mark where they came from).
Thank you!
My Problem
My disk was grinding, a sign that it was about to fail.
My Fix
I copied important data to a file server. Replacing the drive was a snap. Reinstall of the Mac OS X Mavericks was easy (I already had a USB drive available for this). I recovered my data from the file server without a hiccup.
My Advice
It's so easy! Now that I my disk ins't grinding, I'm no longer worried about loosing data and software runs faster too.
My Problem
Hard Drive crapped out.
My Fix
Awesome... didn't take anymore than about an hour.
My Advice
Many hands make the job so much easier. As well as using the repair guide (which is absolutely perfect) watch some YouTube videos so you're completely familiar with the process.
TAKE YOUR TIME!!!
My Problem
Failed SMART status, Apple no longer supports this model.
My Fix
It went well, except the ambient temperature sensor for the 24 iMac run around the entire monitor housing from top to bottom. The previous mac installer had nearly ruined the cable, when I installed this drive, one of the top screws for the metal bezel went through the sensor cable and shorted the machine and threw the heat sensors off, fans went on machine shut down. I soldered the broken wire (one of four) and it's back up. Also ordered a replacement for the future if there's a problem from a supplier here in New York.
My Advice
I think you guys should have a sterner warning for people about this LCD temp sensor. I had it in the proper place, the problem was the screw punctured the cable housing when screwed in, it's happened to many others via Apple support forums. Here's the part number for when someone has this issue if they are unable to repair the cable: Part: iMac Intel Aluminum 24" LCD Display Temp Sensor Cable .works in: iMac (24-inch Mid 2007)iMac (24-inch Early 2008) 2.4/2.8/3.06GHz.Apple part#922-8236.60 and here's a link to the support forum discussion: https://discussions.apple.com/message/24...
My Problem
Defective hard drive. Missed Apple's window to replace defective hard drives.
My Fix
Repair went great. Followed the ifixit instruction's and videos.
My Advice
Watch the videos and follow ifixit directions.
