Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
Please refer to my earlier post here.
Included are images of correct screw length needed.
Good Luck.
Hi, look carefully at this thread
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
check connector #7, place a tape on it just to make sure it's connected properly
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
[linked product missing or disabled: IF182-023]
try a restore ! even if is the hardest way it works every time
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 11,980
