Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
i can hear the caller but they cannot hear me
Score 4
Add a comment
Most Helpful Answer
your microphone may be bad or disconnected, i believe that ifixit has a guide for this.
Score 1
Add a comment
If the microphone is indeed bad, you'll probably be better off buying a whole new dock assembly. Unless you possess mad soldering skillz, you'll find it hard to get everything to go back the way it should.
Score 1
1 Comment:
How do I find out if mic is bad?
by
Add a comment
Seriously, sometimes it's just AT&T's network having issues, especially if you hangup and try again, and it works just fine. This happens to me quite a lot.
Score 1
Add a comment
Have you tried restarting and restoring the phone?
1 Comment:
Yes, but still encounter the problem. Please help. I never dropped it that is why i wonder what happened, the phone is just a year in use.
by
Add a comment
Want to fix the problem, from the above discussion it appears to be the phone mic is not functioning. Is it worth fixing or replacing the mic?
Add a comment
Hi, I’ve just had my charging port renewed on my iph8. When I got it back I noticed when making calls I can hear the person I’m calling but they can’t hear me. I created a voice recording through WhatsApp and it’s just static noise. I plugged my headphones in and made a call again and the other person seems to hear me fine through heads phones, this fault was not apparent before the charging port renewal. Please can you advise ? TIA
Add a comment
Add your answer
Teddy Poynor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 2,506
