Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Recently, the CPU fan started running at full speed. What is wrong?
The CPU/Video fan runs slow at startup, and gets ridiculously fast and loud after a few minutes.
I disassembled the computer to remove 3~4 years of dust on the heat pipe fins, but the problem remains.
It is the nVidia logic board GPU that is running at 160 deg F. It has the CPU/GPU fan running at a full 3600 RPM. Is this in spec or am I going to need to try to re-seat the heat pipes to get a better thermal connection?
Score 1
Add a comment
Most Helpful Answer
did you replace the thermal paste on the cpu/gpu?
i had a few macbooks with heat problems, the paste was hard and almost useless - in other cases, there was way too much of that stuff on the chip's (original apple!).
replacing it is a must!!
Score 5
5 Comments:
+ although nick recommended the thermal paste first, I'm gonna uptick ya. LMAO
by
no, he edited it in his answer after i wrote it - as always (check the history - but i think he will delete his post soon - also as always)
by
you are aware that everybody can see the "edited by" and of course the history of a posting.
by
@ Markus...I was being sarcastic. LOL
by
;-) and nick, it's not that "I" have a copyright on the stuff i'm writing. but it's lame to edit the stuff of an answer in the own answer - only to - yeah - only to what ? get a better reputation score? it's like the deleting stuff that you always do - i delete my answers if the worst case happens and mayer, majesty and answer at the same time - like a few minutes ago.
by
Add a comment
Try downloading a demo of iStat menubar.
Then you will get a good look into the CPU processes and temperatures in your iMac.
heres the program
Score 1
2 Comments:
If you'd given a link you'd have gotten an upvote.
by
i edited this with a link
by
Add a comment
You could also try Activity Monitor, which is included with OS X.
Add a comment
Add your answer
Jeff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,554
